Streaming with Uniti
Posted by: Mark Carwardine on 11 February 2015
Hi, I am new to this and have purchased Asset UPnP, I find it drops out a lot. Is this due to the software or my WIFI connection?
Thanks,
Posted on: 11 February 2015 by Bart
Thanks,
Odds are it's the wifi.  Try wired ethernet and see if that helps (if you can run a cable, even as a temporary measure).
Posted on: 11 February 2015 by Mark Carwardine
I also had the same thought, i did try this but I could not get it to work at all. I guess i need to change the settings somehow to get it to pick up the ethernet rather than the WIFI.
thanks,
Mark
Thanks,
Mark you may be having the issue described in this note in the User Manual:
A NaimUniti 2 switched on without a working wired
network connection will only be able to connect to
a home network wirelessly. To use an Ethernet (wired)
connection, switch NaimUniti 2 off, connect the network
and switch it on again
Posted on: 14 February 2015 by Mark Carwardine
Wired connection works fine thanks.
