Missing programmes on "Listen Again"
Posted by: Tice7 on 19 February 2015
Until recently I was able to select various radio programmes on “listen again” via iRadio on my NDX. However, when I try and do this now I get a message that shows "no shows available" despite the fact that they now stay on listen again for four weeks.
I have reset all of the presets to the new streams but that has made no difference. Is this problem a side effect of the reset streams or is there another reason? I've e-mailed vTuner but have yet to receive a reply. Any help would be greatly appreciated.
Posted on: 19 February 2015 by Mike-B
If you are talking BBC (?)  then its all a bit of a mess at mo
BCC are reorganising all the iRadio streams & play Listen Again is affected.  Take a look around the forums iRadio & Web Radio threads that started a few weeks ago.  Some contain links to BBC were they tell you whats going on & also lots of apologies as it seems they have received a bit of a shock over the level of revolting listeners.
Posted on: 19 February 2015 by Tice7
Thanks Mike. They are all BBC Radio 2 programmes that are all available on my laptop but no longer via my NDX. A few programmes are still available but annoyingly, not the ones I want.
