Techiephobe advice required for NDX!
Posted by: Jason on 02 April 2011
Just considering where I want to go for the future ie: retain CDP and upgrade with power supply, or change CDP for NDX/HDX.
At present, I could afford to change in my CDX2 and get an NDX but can't stretch to an HDX. I do not have any NAS, just a laptop and desktop both with itunes loaded and both running via a wireless "N" Belkin router. I have itunes on both computers and find that easy to use.
Would I currently be able to use the NDX to access music from itunes wirelessly on my computers, or is it not as simple as that? (My router would not be easy to wire to)
Long term, I would look to have a dedicated NAS or even a unitiserve if funds permitted, but it may be some months before I would get to that stage, so want to know how useable NDX would be with my current situation.
I guess the other consideration is I probably have a right mix of music file types on itunes, so is that easy enough to convert to make play on NDX?
Jason.
