Asset question
Posted by: quickben on 09 March 2015
I had an enjoyable hour or so at Accoustica's Chester show yesterday and spent some time with Phil from Naim discussing options for my current setup, specifically the Synology NAS serving a NAC 172 XS in my lounge, controlled from the iPad and a UQ2 in my shed/office. As wifi does not extend to the shed and everything is wired, UPNP control is either by the remote or through my Windows PC. I have been using Minimserver to successfuly ensure gapless playback however Phil suggested Asset as a better option, running it from the PC (as not supported directly on the Synology).
Downloaded Asset yesterday and after a couple of attempts successfully scanned the NAS and used Asset Control from the PC to manage playback. Tried out with DSOTM and Camel's Snowgoose to check the gapless playback and was quite disappointed that it totally failed - buffer visibly cleared and refilled and about 1 second gap. Having noticed that I now had Asset available directly on the UQ2 I used the remote control to play the same albums directly, without using Asset Control on the PC. Perfect gapless playback with the buffer seemingly coping ok. The Asset screen on the PC now shows track progress but no tag information, so I am now quite curious as to why the difference.
And before you ask, yes I might get round to putting in a wireless access point in the shed to use the ipad once I find my old Netgear router and figure out the setup!
