Mu-so firmware beta testing
Posted by: TJ on 10 March 2015
Hi All,
Over the next couple of weeks we will be testing a firmware update for Mu-so. If you would like to be involved then please post here along with details of your system and other useful details such as UPnP server, iOS or Android, Wifi kit, which language you use the app in etc.
Remember that Beta testing involves loading and using firmware that may not be the final candidate for public release so it may have minor issues. Generally when we release to public beta most of the gremlins have been ironed but there is always the chance of running into bugs, so please only get involved if you are comfortable with using pre-release software.
Tom
Hello TJ
Does this FW update add the possibility of adjusting the treble on the mu-so, which currently rolls off sharply at 8000 Hz ?
Thanks,
J-E
Will it reduce the audio drop-outs on the internet radio ?
Hi TJ, I'm up for it; using Muso connected via ethernet, streaming music from iMac with attached HD, Asset UPnP, Spotify. Contolled with iPad. Contact details in my profile.
Im intrested to the Beta firmware.Using Mu-So connected with ethernet and streaming music from Synology 214 Play NAS,i also listen to music via the internet radio.
You can count me in. Using a draytek network and iomega Nas drive. Operated by apple ipad and samsung android phone.
Should have also said, if relevant, that main HDX and 500 system on same network, and also using second system of qute2 on same network? Files on system are all wav
Hi TJ
I'm in as well. Bought a mu-so on Saturday and really enjoying it so far.
Server is a UnitiServe. Listening mostly with uPnP. Also have a SuperU and 2 x Qutes around the house.
Connected wirelessly (which works surprisingly well so far, even on 24 /48k material.
Hi, I would like to test the beta release.
Wireless connection, streaming Wimp/Tidal from iOS and UPnP from ASUS N66U.
Hi TJ,
I'm interested in beta testing.
I have a Sagem VDSL2 F3464 router, wired connection.
I use Bubble UPnP server on my Android phones (wireless) or MusicBee on my laptop (wireless). Happy to also use MinimServer on my laptop.
App is used on Android devices (Sony D5803 with Android v4.4.4 and HTC One X+ v4.2.2).
Tom
Yes please.
Source: Zoneripper MAX NAS (Windows Home Server/Asset) & internet radio (Switzerland)
Streamers: Linn Klimax DSs, Sonos Play 5 and Mu-so.
Control: Macbook Pro (OS X 10.10.2 ) and iPad Air 2 and iPad mini 3 (iOS 8.2)
Connection: Swisscom modem, Netgear GS108E Plus switches wired to all rooms & Airport Extreme & Timecapsule for control.
Mark
Yes please
Using wireless connection, streaming FLAC files from ReadyNAS 102 (using built in ReadyDLNA server). Main NDS system wired to same network. iOS control devices.
Hi,
Yes, I'm interested in beta testing the mu-so firmware.
My mu-so is hardwired to a Netgear 16 port switch, with streaming in FLAC from an ns-01. I use ios on an iPad mini to control, in English. I also use iradio and Spotify.
Andy
Count me in. Wireless only (Sky Broadband/router); iOS apps; mainly Spotify, Internet radio and as speaker for laptop via Toslink, occasional FLAC via uPnP using Windows Media Player.
Neil.
Hi TJ
I have everything.
Well, just about...
jon
Yes, would like to participate. mu-so is usually connected via Ethernet to Neatgear GS108T switch. Mostly listen via UPnP from MinimServer on Apple iMac which is connected via Wi-Fi 802.11n to Airport Extreme, also on NetGear. This works well even for FLAC 192kHz. Sometimes use AirPlay. Naim iOS app as controller. Sources are iTunes library (AAC, ALAC), some HD files and MinimStreamer for BBC HLS streams.
Yes, I am definitely interested .....
I dont mind doing it
usually use it for spotify and Internet radio over wireless on a bt home hub 4 in my kitchen.
usually use an iPad air 2 or an iPhone 5 to control unit also have a unity mk1 on the same network linked to hub by Ethernet cable
I also have acces to two android pads that I donated to my kids so could use them to control it to
ones an Alcatel one touch and others an asus pad not sure of make
my apple stuff uses ios8 and believe the android pads run jelly bean up
sometimes I use AirPlay and Bluetooth when people come over with there phones etc
i'll get involved as well.
OS X and iOS on a 2010 macbook air running off of a VM superhub via wifi. digital input from pioneer TV.
Thanks for the offers, Several names here I recognise as regular contributors which is great, looking forward to having you on board.
All the discussion about beta releases is done on a closed forum here, You should all be added soon. When you have access you will see the beta group listed alongside the other forums here:
https://forums.naimaudio.com/forums
In the meantime I also need some more details from you. To install the mu-so firmware you need to be running the beta version of the naim app. See below and email me direct at tom.johnson@naimaudio.com
Apple iOS
I need the email address you use as your Apple ID. If you are unsure what I mean go to the App Store app on your iPad/iPhone and scroll right to the bottom of the first page, it will show you what Apple ID you are signed in as.
Android
I need your preferred contact email address, I will send you an invite to install the beta Android app to this email address.
@Glyn, Can you mail me the email address you log into the forum with, there are two "Glyns", I need to know which one you are
@Jan-Erik Nordoen, This is not a specific issue I am aware of. If changing loudness and/or room position setting from the app doesn't give you the desired effect I will get our support team to contact you
@Super, RE iRadio dropouts. The answer is .. quite possibly. Assuming your problem isn't related to local network setup or the quality/latency of the station you are listening to then there is a fix in the beta release that may help you. Let me know if you want to join the beta group.
Hi All,
Tom
I'm in. Mine is hard wired and attached to a Unitiserve. Details in my profile. Hope it'll fix the lack of 'gapless' playback.
@pete, Thanks for the offer, the next release doesn't add gapless, but I have a feeling it will come in the release after. I will get you added to the beta team, could you email me your email details as per my post above.
We have enough volunteers now, Thanks! If you are still interested by all means post but you probably probably won't be added to the beta team for this round of testing.
TJ, great look forward to helping. My system is as follows;
Studio; Pre amp, 202 (olive) + Hi Cap (1st gen) + NAPSC (1st gen), Power 200 NAP (current), ND5 XS (hard wired) + XP5 XS, Unitiserve 2TB, Headline + power, Royd Prior speakers ( 2 way).
Office; Mu-so (hard wired)
I use Apple apps. All my stuff is hard wired.
PG
TJ - sorry I missed your message. I'm not actually sure how I mail you my email address? Apologies.
Glyn
Glyn
PS I think I'm the only Glyn with one 'n'?
