UnitiQute unable to see NAS.
Posted by: rn on 11 March 2015
My UnitiQute has been working as normal up to a week ago. It now shows the message "ERR Source, unable to browse". There is no problem with internet connection as iradio plays OK. The same problem is on a Marantz 610 in another room. We run two Windows PCs, one is connected to the BTHome Hub/router and the WD mybook live NAS is connected to the BT home hub. The PCs can access the music directories and play files.
I presume something has changed on the PC connected to BT router. I suspect iCloud may have something to do with the problem.
Has anyone any simple ideas before I un-install the NAS and start again?
Posted on: 11 March 2015 by nickpeacock
This may be no help at all, but...
The one time I found that my (ND5) streamer could not see my (Synology) NAS it turned out that the NAS had updated itself overnight and as a result I needed to reinstall the Media Server package. Simple check-box exercise via the NAS control panel.
Different NAS of course, but maybe worth checking whether whatever upnp programme you use needs to be re-started...
Posted on: 11 March 2015 by nudgerwilliams
Couple of suggestions.
Could be a discovery issue - have a read of the sticky thread.
And switching everything off and on again may fix things.  Suggest switch the router, NAS and Qute off.  Then power up the router, NAS and Qute in that order.  Wait for each device to have finished it's start up before going to the next one.
Posted on: 11 March 2015 by Huge
Some models of the BT Home Hub are notorious for causing problems.
See https://forums.naimaudio.com/to...pnp-discovery-issues
It's also often worth adding a simple unmanged switch into the network, they're cheap and isolate the audi traffic away from the vagaries of the BT device.
Posted on: 11 March 2015 by rn
Sorted. Thanks for the replies, I was able to fix it by reading this thread;
https://forums.naimaudio.com/to...y-twonky-help-please
I re-indexed the database and it now is fine.
