DAC won't play 24/192 FLAC
Posted by: Checkthisout68 on 14 March 2015
Hi, I have a number of such files on my HDX. HDX signal goes into Naim DAC and from there into Supernait 2. The files are being played as I can see from the HDX display but the DAC does not seem to forward them to the Supernait. The files are ok, they all play well directly from the HDX.
What could be the issue with these files and the DAC?
Thanks,
Chris
Posted on: 14 March 2015 by Brubacca
Are you using coaxial digital or toslink (optical) digital between HDX and DAC?
Some toslink (optical) are only rated to 24/96. I can't speak specifically to your components as iam not familiar with them.
Posted on: 14 March 2015 by Checkthisout68
Hi Brubacca, this could be the reason. I am waiting for my NAIM DC-1 cable BNC-BNC to arrive in a few days and I am using a standard Toslink cable in the meantime.
Will wait for the DC-1 to arrive and should be fine then if you are right.
Thanks a lot
Chris
Posted on: 17 March 2015 by Checkthisout68
Yep, DC-1 solved the problem, playing all kinds of Hi-res files now perfectly.
Posted on: 19 March 2015 by Brubacca
Excellent!
