App Volume Control Question
Posted by: PG on 07 April 2015
Firstly apologies if this has been covered elsewhere on the forum, but I don't seem to find any mention of this.
The slider volume on the Naim App does not show 0-99, just its position on the slider, I guess relative to the volume limit set on the app. However the Qute app on my mac also has a slider volume but also shows 0-99. This feature I find really useful and was wondering if it was possible to show the numerical volume value in the Naim App?
Posted on: 07 April 2015 by ChrisSU
It must be technically possible to do this, if you can persuade Naim that they should?? Presumably, your Qute is the same as my Superuniti in that it displays the numerical volume level on its display. For me, that's enough, I can usually see the display panel if I really want to know.
Posted on: 07 April 2015 by PG
Yep, mine is the same, except my 172 sits in a cupboard with a solid door in front which is generally shut.
