Uniti2 Clock
Posted by: CGEM on 08 April 2015
Has anybody else been having a problem with setting the clock since they went forward? I have looked at the other comments and have obviously tried manually adjusting the time zone but nothing seems to work. I am an hour behind. Any ideas anybody? Ta
Posted on: 08 April 2015 by ChrisSU
There are a number of threads covering this issue, but the short answer is that Naim are aware of the issue and are currently working on a firmware update to solve it.
Posted on: 08 April 2015 by CGEM
Thanks for the quick response. I will await the firmware fix which I assume will be fairly quick because this is a basic flaw in such an expensive piece of technology.
Posted on: 08 April 2015 by Gingerbeard
Yep, my Qute2 doing exactly the same. Thought I was going bonkers as I had tried everything I could and it just wouldn't store. I'll await the firmware up-date, hopefully with some other more exciting inclusions
Posted on: 08 April 2015 by hafler3o
Check Phil Harris' posts on this subject, it depends on user choice as to whether the bug takes effect. Both my Qute2s are still working fine and showing the right time. As far as I remember I rejected the daylight saving option.
Posted on: 08 April 2015 by nudgerwilliams
You can fix it now by doing a factory reset.  But you will then lose any config you have done, eg renaming inputs, disabling inputs, max volume limits, remote control config, etc etc.  If you want to do this then per hafler's post the details are in the Phil Harris posts.
