NDX BC SW version
Posted by: Krilin on 12 April 2015
Hello all,
I bought my NDX in nov. 2011. I never updated the firmare and its version is 3.7.0.0.
There are 2 kinds of information from Naim regarding the compatibility of this unit with 4.1 firmware version (and previous ones also I suppose):
- https://www.naimaudio.com/updates: the unit is compatible if firmware version is already in version 3.0.0.0.
- https://www.naimaudio.com/news...ives-naim-streamers: the unit is compatible if BC SW version begins with "3D"
My BC SW version is 11883. Does it mean my unit is not compatible? For information, it is able to play 192kHz/24bits files. So the board is 192kHz/24bit compatible.
I thought there were only 2 HW versions of the NDX: with and without 192kHz/24bit capability. Isn't it? Mine is 2011 and it is the year the change has been made from Naim (when I bought it I take care to have the new HW version).
Anyone has a non "3D" BC SW version with a 4.1 or 3.22 firmware version?
Is there a sound quality improvment to expect by updating to the new firmware versions from a 2011 version?
