Simple Audio Roomplayer + Clicks / Pops Before Track
Posted by: endlessnessism on 13 April 2015
Following the demise of Simple Audio I have bought very cheaply a couple of their latest (final) Roomplayer + streamers.
The idea was that, until Naim start producing multi-room streamers with access to Qobuz, etc Simple Audio would do more or less everything that Sonos can do, while also handling 29/192 files which Sonos cannot do.
This has largeyly proved to be the case. The interface is not as slick as Sonos (eg the ipad / ipod app is out of date and won't be updated and you can only access Qobuz via pc). The SQ is arguably better than Sonos, with one exception: you get a very annoying click / pop at the start of each track.
As par as the click / pop is concerned, both of my Roomplayers feed, via toslink, into Naim DACS. According to Simple Audio's FAQ, it's the Naim DACs that are responsible for the click / pop and there's nothing Simple Audio could have done about it. This doesn't ring true - I feed Sonos into the same Naim DACS and don't have the same issue.
Can anyone suggest a solution or should I conclude that the company's demise was not entirely unwarranted?
