nd 5xs turns on in the night
Posted by: Rbt1 on 13 April 2015
hi all, Just wanted to see if anyone has experienced this. My nd5xs turned on unexpectedly 2 nights in a row from standby mode. Does anyone have an idea what might cause this? It's not even 1 year old. Should I just take it to the dealer and let him check it out.
If it happens on iradio then you probably have the latest firmware installed. Its a known bug. If you wait long enough Naim will fix this fault but probably introduce other faults along the way. But hey at least its not a premium branded product you have purchased. Oh it is
yes it happens on iradio. so that means just wait and see if a fix comes along. in the mean time should i shut it off at night as a work around? or turn the volume down before i go to bed
thanks for your info
Switch it to an unused input. That will stop it.
Made me smile ![]()
My UQ is staying well away from any firmware upgrades and is running happily on ver 3.21 but this doesn't help Rbt1 because I don't think you can roll back to an older firmware.
As Foxman mentioned you will just have to wait until Naim eventually release the new bug free version!
To be fair i leave mine on another input as it seems to only affect iradio, but just to be sure turn the amp volume down also. belt and braces. I wouldn't turn the unit off though.
Thanks everyone for the information. It is a great community
