Muso radio problem
Posted by: Charley on 25 April 2015
Hi all,
I stream bbc1,2,4 & 6 mostly, WiFi through BT Infinity. Sometimes the radio just stops, then picks up briefly, then stops, & cycles like this to utter frustration. It happens with a wired connection, & Spotify streams fine. It only happens occasionally, but drives me mad. Can be triggered by other devices being used on the network I think, but as I say, Spotify no troubles. Is it just me? Considering buying a runner for the reliability, which seems a bit poor show! Other experiences / a solution sought...
Posted on: 25 April 2015 by Charley
*tuner*, not runner.
Posted on: 26 April 2015 by Super
I had a similar problem with the internet radio with a lot of audio drop outs (discussed elsewhere on this forum) whether it was wi-fi or ethernet connected the problem was the same. I'm sure a lot of it was related to the taxi rank radio a couple of doors down. Anyway changed the ethernet cable which was 5m long from a cheap CAT5E to a chord company C-stream CAT7. Problem seems to be solved.
