Split FLAC into tracks under MacOS
Posted by: AMA on 25 April 2015
How to split an album in single-file *.flac with *.cue down to separate tracks under MacOS?
Posted on: 26 April 2015 by Aleg
Max from sbooth-dot-org will do it.
Posted on: 26 April 2015 by RikkieB
Hi AMA,
I use the app Cue Splitter on my MacBook. It works fine.
Rik
Posted on: 26 April 2015 by jfritzen
I'd use XLD, e.g. according to manual
xld -c hoge.cue -t 1,3 hoge.flac
would split hoge.flac with hoge.cue, and decode the 1st and 3rd tracks.
Usage via GUI is also possible as far as I understand.
Posted on: 26 April 2015 by garyi
Its quite easy in XLD in the prefs just ask it to split by cue, then drag the file and que onto it and bobs your uncle.
Posted on: 26 April 2015 by MartinKocurek
XLD works perfectly.
Posted on: 26 April 2015 by analogmusic
Hi AMA
Are you interested in a compare of a Chord Hugo against your KDS?
I'm willing to wager that the Hugo won't be embarrassed by the KDS.
Posted on: 26 April 2015 by Bart
I use XLD; I just "open" the .cue file, and the .flac individual files turn up in the directory specified in my Settings.
