Naim NDX - Fault 34. DSPDAC not booting
Posted by: hertz on 26 April 2015
I started up my Naim this morning and got this error. " Fault 34. DSPDAC not booting ". What does this mean ? What should I do next ?
Good morning hertz.
I had a Fault 35 on my NDX recently.
Here is the thread:
I did try rebooting a few times. Next, I am trying a 24 wait and reboot. Lets see what happens !!
If by a 24 wait you mean waiting 24 hours, I wouldn't bother. If the fault does not clear by turning off few a few minutes, waiting a whole day won't make any difference. I'd drop a line to Naim support. It may be that reinstalling the firmware will fix it, but you should definitely check first.
@ Hungryhalibut,
I tried again with no luck.
How do I get in touch with Naim support ? Via a dealer or can I write in ? Will they guide me through the process of installing this firmware ? Is this a common occurrence ? I was fearing the worst. I am in Asia. I had bought this unit in Singapore.
@ Hungryhalibut,
It's right here at the top of this forum:
https://forums.naimaudio.com/topic/naim-support
Good luck!
Hi Bart,
Thanks. I have sent them an email.
Cheers !
I had the same problem with Fault 35 and NDX freezes ! As far as I see if I try to use Iradio or Vortexbox (which uses digital sources) it gets this Error but If I use TV or Apple TV it plays music or sound ???
