Original Uniti Update
Posted by: Ellsworth on 18 May 2015
Afternoon all. Im sending my original Uniti into the dealer tomorrow for the 24bit/192kHz upgrade. I deliberated about upgrading to a Uniti 2 but Id rather spend the extra cash on a power amp upgrade as I think that upgrade route will offer the most flexibility - especially with the rate in which Naim are developing their streaming products.
So the question is apart from spotify connect, will the upgrade allow me to use multiroom too? Ive searched and the results to this specific question seem ambiguous. The dealer didn't know either! Im assuming it won't include the bluetooth upgrade too as that will need BT hardware? Thanks in advance.
Don't know, probably yes . . . but the dealer certainly should know before accepting your money. If it were me I'd want to know what I'm buying, and any dealer worth their salt should be able to tell you.
Defo won't do Bluetooth.
So you're planning to bypass the power amp section of the Uniti? To significantly better the Uniti power amp you'll probably need a NAP200 at least. There's a lot of waste in that approach, ie the original board of the Uniti and the redundant Uniti power amp section. Might be worth comparing it to a 172xs/155sx which has no redundancy, as well as a Uniti 2, Nait/ND5 and SuperUniti, maybe 2nd hand, before opting for the board upgrade.
This is new to me. The firmware 4.1 cannot be applied to the uniti1 because of a bug that you will hit. See https://forums.naimaudio.com/to...date-failed-fault-61 But the german support had told me that in the next firmware version this bug will be fixed. They said that they already had a beta version of the new firmware and tested that it works with the old uniti... So I am waiting for it.
"NAP250 and deeper sound"
This sounds very interesting. Do you mean deeper in bass or deeper in 3D depth somehow?
I had my original Uniti upgraded to the 24/192 board, multi room works great with when used along with my Qute.
i thought firmware 4.1 could be applied to all the Uniti products including the original models, 4.1 does not support use of the n-link iPod cable.
4.1 can be installed on *ANY* Uniti Product that is already running 3.00 or later (if you are on earlier software to that then you should contact us first).
There have been *SOME* units that have exhibited a 'Fault 61' error when updated to 4.1 and they can be reverted back to 3.22 and this appears to be a software issue that 4.2 will resolve but otherwise 4.1 can be applied to *ANY* 3.00 or later unit.
24/96 units running 4.1 code will not have multiroom or Spotify Connect support but will benefit from the other 4.1 fixes and so I would recommend keeping your units up to date.
At this time we have no plans to roll off support for Qute1 or Uniti1 products - the only 'unsupported' facility is the n-Link connector that was used on the very earliest Uniti's and those units can be upgraded to full digital iPod and 24/192 spec if required.
Phil
Good information Phil as to the continuing support of the older Uniti1's. Mine is a newer Uniti with 24/196 board, and I just find it to work fantasticly and have no reason to upgrade to anything else at the moment. Simple box with a lot of good music, I call it the Swiss Army knife of hifi!
Tim
I think we do a lot of really good kit but IMO the Qute is one which stands out as definitely punching above its weight ... for a small box it does a lot and does it well.
Mind you I also really love my old v-Vi too!
Phil
Phil
+1, value or money for my qute 2 is incredible
Phil Harris,
1. Firmware 4.1 had the daylight saving time bug (changin the time by 1 hour was not possible). Has this bug been resolved by version 4.2?
2. Can firmware version 4.2 be installed on my UnitiQute-1?
Phil Harris,
Hi,
Yes and yes...
Phil
Phil,
Great news, thanks. Final question:
When will firmware 4.2 be released on your website so we can download and install?
Cheers, Bert
Phil,
Cheers, Bert
...when it is ready.
Phil
