Help Wanted Please With Creating Playlists
Posted by: Rogert366 on 18 May 2015
I am a new Unitilite owner and user of the (iOS) App which strikes me as relatively unstable compared to many (but not all) other apps. I had to re-install it today for reasons which I don't think are material. I then discovered that I had lost the Playlists that I had created and used to see on the front page. I had always suspected that I hadn't got these quite right because they didn't appear in the Smart Playlist folder. So, my need for help is pretty obvious:
1 If the playlists had been in the Smart Playlist folder, would they have been stored on my Synology NAS drive and survived the re-installation?
2. How do I create a Smart Playlist (whatever that might be) and get it into that folder?
3. Do Naim produce any sort of manual explaining how to use the various features of such a complex app and, if not, would they PLEASE consider doing so?
Thanks in anticipation of much needed help.
Roger
