Accessing Synology NAS after fimware update to 5.2-5565
Posted by: Phil Harris on 20 May 2015
Hi All,
If you are having issues accessing files and folders on your Synology NAS after updating to the 5.2-5565 firmware then welcome to my world of pain ... I had this issue and Synology weren't too keen on admitting that there was an issue caused by the firmware update or helping out so hopefully this will help you.
It seems that the 5.2-5565 firmware changes the way that the guest account / user group works and I found the following 'fix' which has also worked for a couple of customers since...
Go into the Synology Control Panel,
Go to “Group”, select “users” and “Edit”,
Go to the “Permissions” tab and select “Read/Write” for all of your shared folders on the NAS and “OK” that.
Then go into “User”, select “guest” and “Edit”,
Go to the “User Groups” tab and you should find that the tickbox for “users” is selected, if it isn’t then select it and “OK” that.
That should sort the problem.
Phil
