Naim app question
Posted by: Phantom Listener on 23 May 2015
Hope someone can help.  I'm controlling my Unitilite via the app on my iPad (generally without any problem), but my partner would like to use the system when I'm away - I've downloaded the android app onto her Samsung Galaxy tablet, but it can't "find" the room.
Can you use 2 different apps to control the Unitilite (not at the same time!!), and if so how do I get the android version to find the room?
Thanks for any help.
Posted on: 23 May 2015 by ChrisSU
You can use the app on as many different devices as you like, if one is open you just have to close it before another can access the streamer.
Posted on: 23 May 2015 by hungryhalibut
Try turning the UL off and on again.
