Simple Audio Roomplayer + Clicks / Pops Before Track
Posted by: endlessnessism on 05 June 2015
I have posted on this before but, although it was only recently, the topic appears to have been closed to further answers. Hence I am posting once again.
My aim is a hi def / uncompressed / multi-room solution that will also give access to Qobuz. One or two other requirements as well but that will do for now. As far as I am aware, there is currently no product on the market that answers the above requirements. I'm sure Naim will get there and the sooner the better but meanwhile I am working with stop-gap solutions.
For now, Sonos is a brilliant solution and, played into Naim DACs and amps, it is very close to what I want - but it will not play hi def files.
Simple Audio are sadly out of business. On the plus side, the Simple Audio Roomplayer + is cheap on eBay and it generally sounds better Sonos and does everything that Sonos does plus hi def. On the negative side, I am struggling with an annoying click / pop between tracks that I cannot resolve.
Some observations:
The Simple Audio help site acknowledges the existence of these clicks / pops but says it's not Simple Audio's fault and instead has to do with the choice of DAC. (I use Naim DACs in all my locations).
I get the click / pop whenever I play something from my NAS that I have ripped myself. This includes CD rips I have made on a Naim HDX that I used to own; vinyl rips made with Audacity; and CD rips made on my laptop with dBPoweramp.
Whatever Simple Audio themselves may say, the clicks / pops are not DAC-related. I get them even in those locations where I use the in-built DAC and amp in Simple Audio, with no external DAC.
I do not get a click or pop on albums that I have downloaded. It doesn't seem to matter whether I have downloaded from Naim, HD Tracks or Qobuz - in all these cases there is no click or pop.
Nor do I get a click or pop between tracks when streaming from Qobuz.
All this suggests to me that, whatever Simple Audio may say, the problem has nothing to do with my DAC. I don't have the same problem with Sonos so it may well be peculiar to Simple Audio. Nevertheless, the fact that I don't get it with downloads or tracks streamed from Qobuz suggests that it may well be curable - perhaps not for albums that I have already ripped but at least with new rips if I can do them in a particular way.
Anyone got any ideas?
