Unitiqute power socket and switch
Posted by: J1WPR on 07 June 2015
hi,
just bought a unitiqute 2 and found that the power socket and switch are loose in the casing.  That is, i can move them, they are not seated tightly.  Is this a fault on mine, or are they all like that.
thanks for any replies.
Posted on: 07 June 2015 by ChrisDH
Hi,
it's meant to be like that, mine is exactly the same (and is the same on my other naim equipment), I can't remember the reason why, I'm sure someone will post why they're built this way.
Chris
Posted on: 07 June 2015 by Huge
It's to reduce the detrimental effect of vibrations entering the casework via the mains cable.
My ND5 XS and Nait XS-2 have the same arrangement.
Posted on: 07 June 2015 by Richard Dane
There should be a small amount of vertical and lateral movement in the IEC socket within the rear panel - this is perfectly normal and done like this by design to ameliorate detrimental vibrational and microphonic effects fed via the mains lead to the casework.  It's a small detail, but lots of small details all add up to something larger and more significant.
