Minimstreamer - DSD?
Posted by: MartinKocurek on 19 June 2015
Hi, I found this in Minimstreamer user guide:
DSD audio files in DSF format. Valid for local files served by MinimServer (.dsf) only. The output type must be <code>dopwav</code>. The <code>stream.converter</code> property isn't required.
[NEW] If you're using FFmpeg 2.3 or later as the stream converter (FFmpeg 2.0.2 or later in Synology DSM), you can convert .dsf files to native PCM by specifying an output type of <code>wav</code>, <code>wav16</code>, <code>wav24</code>, <code>L16</code> or <code>L24</code>. The default output sample rate is 352800 and the default output sample bit depth is 32. You can override these default values by specifying an explicit sample rate and/or sample bit depth in the output type.
I used setting : dsf:dopwav but DSD is not played by my NDX. Do I do something wrong? Is it even possible to play .dsf with combination of NDX,NAS Synology 212j, Minimserver, Minimstreamer?
