Naim mu-so electrical leakage on metal chassis
Posted by: ptjw on 23 June 2015
Hello all, i have owned my mu-so for about half a year now and I have always noticed that whenever I place my fingertips at the corners of the metal chassis and the sharper corners of the volume dial when it was powered on I would feel a constant tingling ant-bite like a very mild constant static discharge. It causes enough discomfort to prevent me from keeping my finger there, and it always only happens at the same few places (corners of the metal chassis and corners of the volume dial) so much so that I try my utmost to not touch the unit at all when it is on and just use the remote or the iOS app.
I contacted Naim a few days after I unboxed the unit at home which was a few months ago and they told me it passes electrical safety standards and that some people might be more sensitive to this than others (maybe I have thin skin :/ ). I contacted the dealer where I got the mu-so from and they also told me the same thing that my unit isn't defective and it was due to the metal chassis.
I did not read anyone else on this forum having any issues with feeling ant-bites every time they touch their mu-so and I was wondering if this was indeed 'normal'. It only happens when I touch it with one finger, and the feeling goes away if I touch it with two or more. I live in Singapore where the humidity can go up to 90% or more, but I'm unsure if this is a contributing factor. Anyone have any thoughts?
thanks and regards!
