iRadio BBC 4 Live Stream Problem
Posted by: GraemeH on 28 June 2015
I'm sure I've read about streaming issues with BBC Radio 4 Live. I can't seem to get it through my UQ2.
BBC Radio 4 LW is fine.
A search of the forum isn't helping - Am I missing something?
Posted on: 29 June 2015 by Phil Harris
No issues here on my Qute2 or QuteBlue ... what problems are you having?
Phil
Posted on: 29 June 2015 by GraemeH
Phil
Thanks Phil. Try to load the station and it just stalls.
Virgin Superhub (latest) into Netgear 10/100 switch at 60KBps should be OK?
If it is just me then this can go off line for support - I thought a problem existed from the BBC end.
Which station are you trying to access?
Can you update your unit to 4.3 (posted up today) and - if yours is a 24/192 unit - you will be able to access all the BBC HLS streams.
Phil
Phil
BBCRadio 4 FM Live and, thanks.
Posted on: 01 July 2015 by GraemeH
For the record the issue is resolved. I found another 'Radio 4' banner to click and it is working faultlessly.
Graeme
