Returned From repair N-vi setting up problems
Posted by: john R1 on 12 April 2011
Got my N-vi back today, having trouble setting it up, when i select disc and press set-up the display for setting up fades away and you have trouble reading it, ? also am out-putting via component have tried several settings but the display on the set up is about 2" off centre going towards the left, spoke to my dealer tried different settings still no luck, said he would send someone round to have a look on Thursday, apart from that seems ok, hopefully its only a setting ?
Posted on: 12 April 2011 by john R1
managed to get set-up menu and naim logo about where they should be on the screen by using adjustment on the N-vi menu, plus it is not fading away like it was, still not helping when trying to play a dvd still about 2" to far over to the left of the screen, have some adjustment on my display but not nowhere near enough to move picture that far over, any one got any ideas, ?
Posted on: 12 April 2011 by Manu
It is indeed a setting issue, your dealer will be able to fix it. Or you can call Naim, they will tell you how to do it by yourself.
Manu,
will ring Naim tomorrow see what they suggest,
Posted on: 13 April 2011 by john R1
Manu,
phoned naim this morning as you suggested, Steve phoned me back took a couple of minutes all sorted, just like to say thanks to Steve from naim for the quick responce,
Posted on: 13 April 2011 by Manu
Told you, an easy fix. But couldn't say how on a forum 'cause if you don't do it exactly as it should, you may mess up your unit big time.
