Adding cover art
Posted by: Manu on 17 April 2011
I have found a software to identify albums without cover art and to download them from Amazone, Walmart and a couple of other buying sites.
It also works with a Naim server but you can't add them directly. to do it : create a folder to save them all and manually add them with DTC. At least they are all in the same folder. You can name your downloaded cover art files after the album's name to easily recognize them.
So it is just a matter of opening the album properties in DTC and to drag and drop your file to the blank window.
More, the softwae is OSF, so free.
Google:
Album Cover Art Download version 1.6.6 for PC
I have seen a Mac version exists, but I have not tried it.
