mac mini help
Posted by: slava on 29 June 2015
Hello!
need advice
witch app prog i can use for best results for ipad as display for mini, to control jreaver?
aslo dave some body such issue, i play music on fujitsu laptop as transport, now take mac mini and it seems to me it more cold and analitic now, and treble now little haras, can it be? Or it just my mind
Miroslav
there is an ipad app called JRemote that works fantastically with JRiver, so no need to use a screen sharing app. However on the odd occasion i use teamviewer for this purpose.
As for sound quality i would trust your ears.
Graeme
tnx but i need any way possibility to control my macmini to start jreaver and other activity so i also need a prog to use i pad maybe any one know other good app to make this
and about sq also so it is possible to mini sound worst to fujitsu laptop?
You should be able to use screen share or VNC viewer to control the mini from an iPad. I'd also look at setting up some start up scripts to start J river etc when you boot the mini (unless J river has a tick box that allows it to automatically load at start up - i don't use J river myself on my mini)
guys thx nd about sq can some one say how in compare to another pc or laptop, does any one compare ?
+1 for the free VNC app, it works really well for iPad control of headless Mac mini. If you're always on your internal wifi network, no need to upgrade to the paid secure / encrypted connection version That they warn you about in a pop-up...that is most useful I'd you are connecting remotely from the outside.
Also, you don't need a script to launch an app (or mount a volume) at start up, you can do this in Settings->Users and Groups by drag and drop.
Regards, alan
Tnx about progs, but what about sq of mini and did some one try to put linear power supply instead of cord from box?
For info, a remote app it's on its away as is streaming (Qobuz at first) for Audirvana.
If interested, take a look at the Audio Circles site for optimising the Mini for audio playback.
Jude
Big tnx your right in jreaver it use core I see it if I know about this never will buy Mac, maybe you can advice how can make sutable solution on pc windows, or maybe you know other good players that I can use on Mac to find more sutable what other except jreaver and audiorvana can be in Mac?
Guys tnx i like audiorvana but have some problems with vnc viewer it different or mini and on ipad plz can help and say step by step how to install this prog and how it named correctly cos there many vnc in appsore
