itunes 12.2/BeatsRadio/muso
Posted by: jon h on 30 June 2015
if you upgrade to latest OSX and get itunes 12.2, then you will find the new Apple "Beats 1" streaming radio station if you sign up to the free three months trial (I assume it comes with that, I did anyway)
You will notice that the Airplay icon in itunes disappears if you select this. You can only play through local computer speakers. I was listening to my own stuff in itunes to Muso, and went to Beats 1 -- and the sound came from the local computer speakers and the Airplay icon disappeared in iTunes
This is a bug, and its nothing to do with Naim or muso. It is bug in itunes 12.2. So dont panic.
There is a workaround if you want to stream Apple radio to muso (or any other Airplay target):
controlclick on the volume icon at the top of the display, and choose the muso from the drop downlist of destinations. This will force all audio output from the computer to be routed to the muso directly via airplay.
jon
