Spotify connect on mu-so
Posted by: nocker on 12 July 2015
I can only play spotify over AirPlay on my-so which drops out if I use the iPhone for anything else or if the iPhone goes into sleep.
It will not connect to spotify connect even though the logo is visible on iPhone. When selecting it it shows the mu-so but it will not join it.
Any ideas please?
Posted on: 12 July 2015 by Trevor Wilson
hi
please contact naim technical support regarding this, phil will need various data from you to assist
trevor
Posted on: 12 July 2015 by Skip
I had a similar problem but the recent firmware update solved it.  Now the MuSo is working better than ever.
Posted on: 13 July 2015 by nudgerwilliams
Couple of obvious things.  I think you need a premium Spotify account to be able to use connect.  Do you have that?  And sorry if this is too obvious, but you need the Spotify input selected on the mu-so, then go to the Spotify app and use the Connect logo to select your Muso.
