NDX, SN2 - volume level
Posted by: MartinKocurek on 12 July 2015
I have SN2 and NDX connected by remote cable. I can control volume through my iOS app but on NDX  display I do not see volume level indication. Is it ok? I have at home Naim catalogue and there is picture of NDX with volume level indication.
Posted on: 12 July 2015 by Bart
Yes, it's working properly.  Controlling volume the way you are doing it you are controlling the SN2, not the NDX.  You should notice that the SN2's volume knob actually turns when you change volume with the iOS Naim App!
Posted on: 12 July 2015 by Mike-B
Thats the way it does it on my NDX-SN(1)
- the volume level gauge is your MK-II ears synchronized with your digit pressure pad interface on the screen + & -
Posted on: 12 July 2015 by MartinKocurek
Sorry I did not understand, it means I will not be able to see on NDX display?
Omluvy Martin,  I (we) should be more respectful of language & consider our non-english friends. I used to travel a lot to Czech Rep, my company had a factory in Kolin, an R&D & engineering test centre in Hostivice  & a research institute in Prague
- stastne vzpomínky
------  I mean the volume gauge will not be seen on NDX
- stastne vzpomínky
Ahoj Mike-B :-)
dekuji (thank you)
martin
