Third Rock Radio - Radio not found :(
Posted by: Roberto on 14 July 2015
Dear Naim enthusiastic users,
Firs post in the forum from my side: I happily running a Supreuniti together with PL, ProAC D20R and NAC-A5, excellent setup as far as I'm concerned. Little hiccup: since a few days I can't stream anymore "Third Rock Radio", the Superuniti recollect the history but than nothing. It goes into "connecting" but nothing happens. Tried to reinstall the app, reset factory setting, but no results. The same iRadio can be streamed from Squeezebox with no problem. all other iRadios are running ok on the SU. Anyone has experienced the same issue? Would 4.3 firmware eventually help? Any suggestion warmly welcomed! Thanks. Cheers. Roberto
Posted on: 15 July 2015 by Mike-B
Yes its the same as you found on mine  .........  it's OK on other www.
This must be a vTuner - Naim's iRadio partner - problem
Posted on: 18 July 2015 by Roberto
Hi All,
Updated to firmware 4.3, all went well, I have the feeling the sound is even a bit better (maybe an impression!), nevertheless my beloved "powered with NASA" radio is still not connecting .... also Paradise 320K now shows "radio not found", to compensate there is RP Naim Exclusive at 320Kb/s, so not big deal, but still I'ma bit puzzled by the missing Third Rock Radio. Is there any suggestion on how to tweak something to regain the lost radios? Thanks for any suggestion. Kind regards. Roberto
