ND5 XS update to 4.3 (4.03.003)
Posted by: Huge on 16 July 2015
Installation:
All went smoothly.
Left the ND5 connected to my Ethernet network and connected the USB cable. The USB system of Windows (7) recognised the type of USB controller chip in the ND5 and identified that it needed a specific driver to communicate with it. Windows Update identified, downloaded and installed the required driver (and reported that the driver had installed itself on COM3*).
I expanded the Naim updater zip file onto the hard disk.
I the followed the Naim updater instructions (Naim Tech Note TN-0029) included in the zip file.
I ran the Naim updater install pack under Administrator privileges and it installed without problem.
I allowed the install pack to start the updater after installation and that started fine.
Everything then proceeded exactly as the instructions said, the Naim software was intelligent enough to recognise the virtual COM port required for the ND5 (COM3 in my case).
I turned the volume on my Nait to zero, fired up the Naim App on my tablet, and the ND5 started playing the required track; I turned the volume up and 'écouter la' - music ('voila' doesn't seem quite appropriate even though idiomatically correct!).
Observations on sound quality:
Difficult to be certain, but there is possibly a small improvement.
If I did detect a real improvement, then, for me, it's not in the bass as people have reported for the NDX, rather it's in discrimination of fine detail in the presence of strong bass and in a degree of 'naturalness'. In particular I appear to find it easier to hear when the same voice has been multi-tracked singing in unison, even when there isn't a difference of location in the stereo image. I may also have gained some additional clarity when listening to complex counterpoint in Baroque music.
* The driver is used to create a virtual COM port which the OS recognises as the driver for a COM port. However, instead of connecting to a physical serial port on the PC, this driver transfers the serial data to the receiver chip in the ND5 using USB to do the physical communication. This allows serial comms protocols to function over a USB transport link.
