Improving a Mac based system - where to start?
Posted by: Yetizone on 30 July 2015
Hi all,
My home office system is current shutdown due to redecoration, so i'm wondering about using the downtime to investigating what I can do to optimise the output from my Mac to Beresford TC-7510 DAC and CB Nait2. This was implemented quite a few years ago, so I realise the game must have moved on significantly!
The current set up uses an old 2007 Macbook, OSX 10.7.5 (can't go any higher with the OS) using iTunes 12.1.2.27. My CD's were ripped using Apple Lossless and i'm currently using iTunes as the interface as I also listen to a lot of podcasts too. All data stored on an external HD (firewire). I also share the library to an older G5 so that has to be able access the files via iTunes also.
A Chord Company Toslink cable outputs the optical signal to the Beresford DAC. An RCA to DIN cable connects the DAC to Nait. For ref, the DAC has 2x Coaxial Inputs and 2x Optical.
So, what are my options folks?
Can I connect the Mac to the DAC in a better way - with an eye on possibly upgrading to an N-DAC in six months or so? I guess a DAC-V1 is out of the question as it requires OSX 10.7 minimum.
Perhaps some sort of asynchronous USB DAC connector / converter / cable upgrade?
Re-ripping the CD's perhaps to a better format? Happy to do this as I only have a couple of hundred so not a huge task.
Are there any software upgrade possibilities?
A lot of questions I know, but any help most gratefully received by this streaming novice!
