Aurender X100
Posted by: Bill McLean on 06 August 2015
Hi all,
Borrowed an Aurender X100 for a week and was wondering whether it can be set up fof it to recieve rips directly from a HDX. Looking forward to the answer being yes as the X100 sounds excellent.
Bill.
If it was an HDX-SSD I expect you could pull the rips from the NA but for a 'normal' HDX I'm uncertain as I'd expect the dir. to be somehow hidden
As an aside does anyone know if the HDX-SSD employs cached playback?
This appears to be one of the key features of the X100
Hi Bill
i have the N100. You can map a drive to the Aurender so i would presume you can get your HDX to archive to this drive. you don't happen to have it on loan from Paul by any chance as i was chatting to him about this very thing on Tuesday
Graeme
Hi Greame
How right you are, got for about a week and the sound stage is so much better than the HDX but I find ripping using the HDX so convenient, my problem is I have'nt a clue how to make these things connect. If the HDX can rip to the X100 I will buy it, but need a Phil Harris to sort it.
Bill
Hi Greame
Bill
The HDX as only a ripper is overkill. You can absolutely learn how to rip cd's on a computer. If you can connect up a hi fi, you can learn to rip cd's on a PC or Mac!
Bill if i get a chance today i will have a look through the HDX and Aurender manuals and see if i can help. Do you use a PC or Mac, as i would think one will be required to set this up.
i also had an email for the Aurender rep Liam who was extremely helpful and seemed more than happy to drop in should i need his help, ill see if i can find his address.
I also have Eric's address from Aurender which i can forward to you..
Can you email me, my address is on my profile and ill pop the addresses over.
Graeme
Hi Bart,
Can't agree more with your comment but as I have the HDX already it makes things so much easier. I can transfer music from various sources to my NAS and yes it is quite simple but it is all the faffing about with tagging that I try to avoid. My issue is getting things to talk to each other!
Bill.
Bill
I have had a look through the HDX manual and you should take a look at section "7.4 Adding a Music Store". Also in the Aurender manual have a look at "Settings : NAS Share" and "Transferring Music".
Have a read and see if any of it makes sense. As i said send me an email and ill give you those contact details.
Graeme
