Dynamic range meter
Posted by: MartinKocurek on 06 August 2015
is there any program for Mac which can analyze and measure Dynamic range of .flac and .wav ?
Posted on: 06 August 2015 by Bart
I'd check out the computer audiophile forum.  Those geeks will know and use it if it exists ;-)
Posted on: 06 August 2015 by Mike-B
I use MusicScope.  It does a lot more than dynamics - search MusicScope
Posted on: 06 August 2015 by MartinKocurek
Thank you.
Mike, is there also DR value indicator?
Posted on: 06 August 2015 by Simon-in-Suffolk
Hi I use MusiscScope as well - and there are several different types of dynamic range measurement and metering. (Top centre left of display screen)
Posted on: 06 August 2015 by joerand
A good on-line source is the Dynamic Range Database found here:
http://dr.loudness-war.info/
It contains almost 82,000 albums including CDs, vinyl, Hi-Res, Blu-Ray and others.
File formats used for analysis are identified and typically FLAC or WAV.
Posted on: 07 August 2015 by MartinKocurek
So I will see i.e. DR12 and it will be comparable with DR database on the internet?
Posted on: 07 August 2015 by Aleg
If you go to the site joerand refered you to: http://dr.loudness-war.info there is in the top-righthand corner a dropdown menu called links. In it you'll find a reference to DR-metering software for MacOS and that is written by the designer of the DR-measurements and gives you the proper number.
Yes, but only up to 44,1kHz 16bit for MacOs
Posted on: 07 August 2015 by Erich
I also use Music Scope.
I published some results in a thread a few months ago.
Regards.
Erich
