Qute's Time Has Gone Wrong
Posted by: Gavin B on 10 August 2015
I've not had (or noticed) the issues previously mentioned with the time display on other people's Qutes, but yesterday mine has jumped an hour ahead.
I upgraded to v4.3 recently without issues (and in fact sorted out plenty of problems I'd had previously). I expected the process of setting the time to be automatic, but I had to change the time zone to +1. A couple of weeks later, possibly the first time I used the Naim app to control the Qute, it asked whether I wanted to set it to daylight savings. I said I did and everything seemed fine.
Yesterday, the clock was reading an hour fast. I couldn't find any options through the menu to set the time (other than re-sync from the web, which did nothing). I can't find an option to manually adjust the time zone. There's nothing on the app either. Any pointers?
Gavin
