Brandnew Mu-So / Problems with Airplay and Firmware Update
Posted by: Joe Strummer on 20 August 2015
Hi all,
I have bought and successfully installed my new Mu-so last weekend ... however, there are two issues where I need some input:
Firstly, for any reason, Airplay doesn't work. The mu-so (by Ethernet) as well as iPhone, iPad and a MacBook Pro (all by Wifi) are alltogether connected to my Home network. The Mu-So is running (Webradio and iPhone via USB for example) and can be found and controlled by the Naim App. However, all my Apple devices do not show the Mu-So as an "Air Play Speaker" (an Apple TV for example, connected to the same network also by Ethernet can be found w/o any problems by the Apple devices). The "Net Analyzer App" on my iPhone/iPad shows the MuSo connected to the Network but not with the "Bonjour" icon. It looks like the Mu-So is not broadcasting / responding to the Apple Bonjour protocol, which is - in my understanding - a precondition for the Air Play functionality. And now? Any ideas?
The second issue is, that the Mu-So is running on firmware Version 1.01.000. I understood that there is an update available on 1.02.000 and that this update needs to be done through the Naim App. However, the App does not show this update where this should be shown so that I have no idea how to start the firmware update.
Thank you in advance for your answers/remarks. I'm hopeful that someone out there can help me since this forum has been very helpful in the past already (I also own a Uniti and a Unitiserve).
Greetings from Munich,
Peter
