Nsub connection
Posted by: phil. S on 27 August 2015
Hi, just a quick one. I'm getting a Snait2. My nsub cable has a din connector which I previously plugged into my Hicap. Question is will I be able to plug my Nsub into either the "pre amp out" or the "bi amp" sockets on the Snait. Or, will I have to change the cable for one with phonos?
Many thanks in advance.
Posted on: 27 August 2015 by Richard Dane
Will you still be using the Hicap with the SN2?  If so, keep it as is, otherwise you could use the bi-amp pre-out.
Posted on: 27 August 2015 by phil. S
Thanks Richard, so its the bi amp out...great. The Hicap will be replaced with a DR version when funds permit.
