XLD or...?
Posted by: Milija on 01 September 2015
Hello,
I would like to try good software on my Mac to convert CD to Flac, Flac to mp4, AIFF...
Could you tell me what is good software to do it.
Not used it myself ... but there is a version of dbPowerAmp for the Mac now.
I've always used XLD. Agree about the user interface but once set (very easy) then there is no need to touch it.
James
Anyone care to give some guide points for XLD setup?
Ta!
I can never get this program to go into Applications on my Macbook pro, any ideas or guidance chaps would be appreciated.
dbPoweramp here on mac..... just hit the 400 ripped CD's total and have no problems as such.
I seem to remember it was just drag and drop. What's it not doing ?
Yes just drag and drop it into your Applications folder.
Thanks for that, managed to load it into applications. "was trying to load it into launchpad ".
How does everyone get the CD art to load, or do you have to do it manually........
