Can't Turn On My Panasonic HDD/DVD Recorder
Posted by: Gavin B on 04 September 2015
Help!  My Panasonic HDD/DVD recorder won't turn on - either from the remote or from the buttons on the unit.  This has happened before and was solved by pulling the power cord out and re-booting completely.  It was okay for a while and has now lapsed into the same issue.
Has anyone any idea of what the problem is and if there's a solution?
Gavin
Posted on: 13 September 2015 by Dungassin
I suggest that you post this query on AVForums.com, where you may get a solution.
Posted on: 28 September 2015 by Gavin B
Quick update in case anyone else searches with a related problem.
i registered on AVforums as suggested and did a bit of digging before posting my query. A post suggested that when doing a hard re-boot (by pulling out the power socket) said to leave it out for more than 15 to do it properly. I've done this and so far it's behaving.
