Just curious as to how the playlist creation stuff works in the Naim app. I see "add to new playlist" - but where does it go?
Does something have to be set up in Asset for this to work?
Posted on: 04 September 2015 by ChrisSU
A playlist created on the App is visible on the screen beneath the inputs and radio presets. A playlist created on the server is a completely separate thing, and appears as a folder in the UPnP input. Also, you can, in effect, import a UPnP playlist to the app by opening it, then selecting it with the ... option, create new playlist.
