superuniti or separates?
Posted by: Paristhea on 09 September 2015
I am considering upgrading into a superuniti or totally separates.
Of course the superuniti solution is attractive as it will occupy less space.
But i do need to understand the real difference inside the box, between a superuniti and equivalent separates.
1. First of all, which separates are equivalent to the superuniti?  Most importantly the DAC part inside the superuniti, and of course the preamp.
2. I have the option of NAC202/NAP200 plus a source, possibly ND5XS.  Would this result in a better sound than a superuniti?
3. The issue is that the Naim product site does not provide enough technical info to assess what is inside each box, perhaps it is meant to be confidential, i don't know.
Easy answer is to listen to them all and decide, but where is the time to listen to them all.  One should be able to make a short listing of various options and come down to two, then do an audition to decide.
Is there any site that provides more technical info on the differences between the various boxes?
Posted on: 09 September 2015 by Massimo Bertola
Hello,
if you had asked this a few weeks ago someone would certainly have come up with enthusiastic endorsement of the SU, but things change..
Seriously:
1. Difficult to answer. I have had the SU, for about one week then understood it was not my cup of tea. For my taste, room and ears I found it too polite, plenty of power but a little rounded off, civilized. It belongs, in my modest opinion, to a new 'breed' of Naim voices made for a more wide and universal target. I know nothing about its DAC.
2. I have owned 202/200, for about one year, and if I leaned towards separates again, that would be my choice, any moment: real Naim sound, powerful, not harsh but clear, assertive, luminous.
3. I can't answer this either. I have never felt much need to know what's inside a Naim box. What I can tell you is, that if you want a powerful integrated with more of a classic Naim sound and a more than decent DAC on board, a Supernait1 is still, in my still modest opinion, a good choice. If streaming is a priority, you'll probably want a good, separate Naim streamer, but I have heard a lot of times a Squeezebox Touch into the Supernait's DAC, and it was more than enough for me, in terms of quality.
I have once carefully compared a SuperUniti as streamer and amp vs an ND 5XS as streamer into the SU's analogue input, and was barely able to detect any difference. I am beginning to suspect that the digital domain may be the one (DACs, streamers) where the differences are heard less going up or down the range...
Best with your choice
M
Posted on: 09 September 2015 by Paristhea
Originally Posted by maxbertola:
Hello,
Seriously:
M
Thanks a lot, really valuable comments.
I will audition today a Superuniti Vs NAC202/NAP200 and see where this takes me.  My own speakers are Linn 109, plus i now also have the B&W PM1 in my living room, as i am considering buying them (2nd hand of course). Can not get much difference between them so far, and i lean towards the Linn sound so far.  My source is only UQ2+NAP100, maybe that is why.  People say the PM1 are difficult to drive.
Streaming is quite important to me yes, as i either listen to  turntable or digital music stored on my MacMini which acts as a music/media server, and i also use J River Media Centre as software.
If you have anything to add please do.
Posted on: 09 September 2015 by hungryhalibut
The Superuniti is a great product, and perfect if you want a one box solution. I have never been that keen on the 202/200, and bear in mind that you need a napsc and hicap to get it sounding good. If you cannot go there (four boxes), do not get it.
If you can afford a 202 and an nd5xs, I'd suggest you look at the 272. Pair it with a used 200 (you don't need the new DR version) and you have a system miles better than the SU in only two boxes.
They would be my dem options: SU versus 272/200. Simply see if you think the latter is worth the extra.
Posted on: 09 September 2015 by Robbor
I have to agree with HH about this. I went from a Uniti to Superunity, now to 272/250DR. The Superunity is a superb one-box solution (with the usual caveats about individual tastes, so needing to audition for oneself). If you don't suffer from Naim upgrade-itis, the SU is simply very easy and satisfying to live with.
Before I got to my present setup I auditioned a 272/200, which I thought offered a significant improvement, although at a price; so I think the advice about checking that out and considering cost-benefit is spot on.
Good luck with the listening.
Posted on: 09 September 2015 by ChrisSU
I'd agree that the 272 or Superuniti are good options to consider. However, if you already have a Mac Mini, you don't really need a Naim streamer as well, just a DAC (plenty to choose from by Naim, Chord etc.) and amp. If you don't want loads of boxes, maybe a Supernait?
Posted on: 09 September 2015 by analogmusic
what speakers do you own or plan to own?
Posted on: 09 September 2015 by karlosTT
There have been a few other recent threads on this topics, where some users have favoured even the 172/200 over the SU.  The cost is approx the same, whether new or second hand, so it could be another combo for the demo list if at all possible......
The Mac Mini is only a storage, it is not a player.  I thought the streamer acts as a player, is it not?
I already have Linn Majik 109, and i am also currently testing B&W PM1.  But i must say that after two days of listening, i much prefer my Linn 109's over the PM1.
That is why i am going to improve on the source and amplification, before i make up my mind on the PM1.
Well, this is an even better reason why i should chose the Superuniti, in order to avoid the upgrades
A properly configured MM will do everything a Naim streamer will do, and more. You would just need a DAC, whereas all Naim streamers have a built in DAC. Some people prefer this route, which might free up more of your budget for a quality DAC. Others prefer the Naim streamer route. I'm not trying to push you one way or the other here, but as you own a Mac Mini it's an option you could consider.
Posted on: 09 September 2015 by Richard Dane
If it were my choice and the only priority was best performance and I wasn't constrained by space or the desire to have just a neat one-box solution then without any hesitation I would go for the NAC202, NAPSC + NAP200 with either the Naim DAC or maybe an NDX up front.
But I'm me and you are you, so try to listen to each option and then decide where your priorities lie.
Fair point! I think there are two issues in this context:
1. Audio - are you happy with the listening experience from particular kit?
2. Psychological - are you the kind of person who is happy just to go on enjoying your music without getting diverted into analysis of sound qualities and concerns about how/whether it could be "better"?
The answers to these questions may help solidify the approach to equipment choice.....
cheers,
R
Posted on: 09 September 2015 by Minh Nguyen
Hi Paristhea
How long have had your UnitiQute2 + NAP 100 combination? If you have owned that combination for less than 2 years and are already contemplating an upgrade, it is probably best in the long run for you to buy separates. This will leave you the choice of making small incremental upgrades in the future. It's actually a whole lot of fun climbing the Naim ladder gradually. It is also a whole lot of fun sitting down and enjoying music without thinking of upgrades. I would suggest that you consider what type of system you see yourself owning in the next five years and work towards that goal.
ATB Minh
Originally Posted by Minh Nguyen:
Hi Paristhea
ATB Minh
I have had it for about 8 months, but i had always in my mind the Superuniti.
But i will not sell the UQ2+NAP100, it will just go to the bedroom or the office.  I have no complaints from it, it is superb, excellent!!!
Now my mind is thinking about  separates and the cost is climbing fast.
I am even wondering whether the UQ2 would be an adequate analogue source, should i opt for the NAC202/NAP100.  Cause the 272 may be excellent idea but it is also very expensive.
I suppose the separates gives more flexibility for the future.
I guess in 5 years time ideally i would like the NAC272, NAP250 with external PSU.
In which case, think about getting a 272 (which is cheaper than the SU) and using it with your 100. The Qute will be fine by itself. Easy peasy. You can add a bigger power amp at your leisure.
Posted on: 09 September 2015 by Quad 33
ATB Minh
Total agree with the above... Try and decided what you want to achieve and the most cost effective route (new or pre - owned) to achieve your goal easier said than done I know. However, the most important ingredient in any upgrade is finding a good dealer who will give you good advice and home demonstrate your choices without any pressure to buy. I once had a pair of Wilson Benech speakers from my dealer on demo for six months and did not buy them then If in doubt buy more music .
Good luck Graham,
That would make a wonderful combination to aspire towards. Every time you climb the Naim ladder you will be able to appreciate the nuances that distinguish each component. There is nothing more satisfying than sitting down and hearing the music that you love presented in a different manner. It is usually enough to satiate the appetite until it is time for the next upgrade. From here, I would suggest that you buy used until you are ready to splash out for that dream combination.
Posted on: 09 September 2015 by The Strat (Fender)
If you aspire to a 272/250 (excellent choice) then you need a route to get there.  Why not 172/200 and then upgrade to 272 in slower time?
Posted on: 10 September 2015 by analogmusic
Dont know if this helps, but last night I tried my DAC V1 direct into my NAP 200 (compared to Hugo/282/HCDR/NASPC)
No contest, the 282/HCDR was so much better than the DAC v1 preamp.
Once I heard the difference there is no way I could ever sell my 282 and go back to DAC V1 preamp.
Posted on: 10 September 2015 by catalinmetal
yes, at least for my own experience, 172/200(DR version) is better than SU. but there is a slight different presentation so i would rather try them before deciding.
Posted on: 10 September 2015 by Slim68
This is the route (172/200) I took and am very glad I did. I went in looking for a 2 box solution (CD and Amp) but once I'd heard this combo and the benefits of streaming where shown to me I took the plunge. I still use CD as my main source but am looking at setting up a NAS soon. Good Luck and enjoy what you buy.
this is slightly hilarious, since in DAC V1 - to my knowledge - there is only a digital attenuator, and not an active preamp.
BUT, some will be surprised to know that, in certain setups, inserting an active preamp might disrupt the balance and timing... not in many cases, but there were some.
I always thought the DAC V1 had an active preamp?
In any case based on my test last night I am keeping my 202 for my second system. the 202 is no slouch at all despite somehow many negative comments which I just cannot for the life of me understand.
Posted on: 10 September 2015 by Paristhea
Thanks all for the valuable replies to my question and your comments in general.
I paid today the deposit and ordered a NAC272.  I will use it with the NAP 100 for now.  The dealer will take 4-5 weeks to get it as there is a lot of demand, apparently.
I will get the NAP250 next, when i can afford it.
Thanks again.
Will come back and let you know of my impressions of it.
