Re-listening
Posted by: Minh Nguyen on 12 September 2015
Some of you may recall that I bought a new pair of speakers a few months ago. They have three jumper settings to allow the treble to be set at 0 dB, -1 dB or -2 dB. I have been listening at -1 dB from new, because I found the top end too bright. The thought crossed my mind yesterday to try the 0 dB setting. What a revelation! It's as though I am re-listening to we'll known tracks again and hearing nuances that were once hidden. The improved contrast resolves more detail. It's odd. The highs don't hurt my ears anymore. I suppose the speakers are now well run in ????
Posted on: 12 September 2015 by TOBYJUG
No. I didn't know that you bought some new speakers.
Posted on: 13 September 2015 by Huge
Also, at 0dB, the signal will benefit from not having additional gubbins thrust into the electrical circuit, and the speakers will work as the designer intended, rather than as the marketing department insisted!
Posted on: 13 September 2015 by Jan-Erik Nordoen
From your previous posts, it appears that you often listen at very high levels. If this is the case, it is possible that you have blunted your high-frequency hearing. Setting the tweeter to 0 dB may have simply compensated for the loss in hearing sensitivity.
At what levels do you listen (measured in dBA, on a slow setting) and for how long on average per day ?
Posted on: 13 September 2015 by Minh Nguyen
I hope you are well. I see you have been busy fighting the corner for passive room correction.
What on earth is gubbins thrust?
I have been listening to loud music since I was a teenager. For background music I normally listen at 85 dB. For a good listening session it will be around 95 dB for an hour. For a serious session it is 105+ dB for about 45 minutes. I kind of know intuitively when my ears have had enough.
Posted on: 13 September 2015 by Clay Bingham
Jeez Minh
If those are real measured levels I'm not sure your ears are warning you in time. Be careful and reconsider those levels. They're high!
Posted on: 13 September 2015 by Ravenswood10
Yes and speaking as a sufferer who never listened at high volumes tinnitus isn't pleasant...it's there 24 hours a day and there's no cure!!! I can tune mine out during the day but it's literally a real pain at night.
Precisely. At those levels, you're pummelling your ears and brain into submission. By the time your ears warn you (ringing) or your brain (listening fatigue) the temporary hearing loss is already there (metabolic fatigue of the hearing cells, or physical damage to them). Repeating the exposure without a sufficient rest period (14 to 16 hours at less than 70 dB) will render the temporary loss permanent.
As a guide, daily listening time to avoid long-term loss (assuming no other overexposure) is 8 hours at an average 85 dBA (not dBC or dB Lin). Since sound intensity doubles at every 3 dB, exposure time should be reduced by half accordingly. So :
85 dBA : 8 h
88 dBA : 4 h
91 dBA : 2 h
94 dBA : 1 h
97 dBA : 30 min
100 dBA : 15 min
103 dBA : 7.5 min
... and so on until zero exposure above 115 dBA.
Hearing loss is pernicious, permanent and preventable. Worse though is permanent tinnitus, often caused by high-frequency hearing loss. It can destroy your life.
On the other hand, you may be one of the lucky ones who are genetically resistant to noise-induced hearing loss (some people are harder to deafen). The only way to know is to have your hearing sensitivity checked by an audiologist.
Jan (with Erik in agreement)
Posted on: 13 September 2015 by Olek_K
Great info! Thank you Jan-Erik. I'm now at 80-83dB and it seems pretty loud. Actually I can't imagine going louder at home.
Posted on: 13 September 2015 by Steve J
That's around my average listening level as well. Only occasionally will I go higher, but for short periods only. Minh, take heed of what Jan-Erik and Ravenswood are saying. You're young and will want to listen to music for many years to come.
Posted on: 13 September 2015 by tonym
Feedback from recent forum visitors indicate I listen too loud. Measuring it with my App. decibel meter shows about 94dB on average, so they're probably right.
Posted on: 13 September 2015 by Graham Clarke
94?  Blimey that puts some context to 105dB!
Thank for your concern everyone and a special thank you to Jan-Erik ????
Posted on: 13 September 2015 by Quad 33
Hi Steve, hope you caught lots of fish and enjoyed your time with your brother. Just out of interest what sort of volume did you play the system when I visited last year as I don't recall any listening fatigue or discomfort at all in what must have been a good six hrs + of wonderful listening.
Regards G.
Posted on: 13 September 2015 by Foot tapper
Hi Minh
As someone who did a lot of engine testing as a young engineer, I was fortunate to be warned early about the dangers of hearing damage & tinnitus.
Naturally, as a young man, I knew that I was immune to such effects.
As a result, I have suffered from mild tinnitus for circa 20 years.
Eric's advice is very good advice.
The alternative is to follow the dubious advice of Lemme (of Motorhead fame).  When asked if he was concerned that Motorhead's loud concerts would damage his hearing, he replied that he was making so much money that he would simply buy new ears when he hit the age of 40.  He is now much older than 40 and struggles with his hearing.
To the best of my knowledge, new ears are not yet a commercially viable option.
Happy listening and do look after your ears so that you may continue to enjoy music.
Best regards, FT
Posted on: 13 September 2015 by musicnuttyboy
Are the various db Sound Ap's for the iPhone accurate or is it worth buying a dedicated meter?
What are people using for what they are quoting?
Posted on: 13 September 2015 by Dustysox
Originally Posted by Foot tapper:
Hi Minh
Best regards, FT
Well said FT. I hope you are well, and life is being good to you.
Regards G.
About the same Graham, maybe a dB or two higher.
Fishing last week wasn't great because of the easterly winds but I had a good time thanks. Whilst I was there in Devon I looked at some houses to buy for my impending early retirement. I took my wife back this weekend to view them and there is one house we both like very much. Of course I viewed the house with eyes for a good listening room and this one doesn't disappoint.
ATB
Steve
Posted on: 13 September 2015 by FangfossFlyer
Sounds nice!
I've found the best all-round app to be the SPL Meter by Studio Six Digital ($0.99), fine for checking listening levels. Just set it to A weighting and 'Slow' response. I also like the retro look :
(on iPhone)
(on iPad)
Posted on: 13 September 2015 by 911gt3r
Regards G.
ATB
Steve
Did you do the clapping test Steve?  ATB Peter
It's a solid house which is beautifully carpeted throughout and passes the clapping test with easy Peter.
(on iPhone)
(on iPad)
I use the same one. Very useful.
... but the best (and for only $20) is SoundMeter Pro by Faber Acoustics, which "turns your iOS device into a handheld data-logging sound level meter (SLM), data-logging noise dosimeter, and real-time analyzer (RTA)".
In dosimeter mode you could set it up in the listening room and it'll tell you when it's time to quit (dose at 100 %).
In the image below, the criterion level (daily 8-h exposure limit) is set to 80 dBA. Normally this would be set at 85 dBA for an 8-h exposure.
Posted on: 13 September 2015 by GraemeH
I remember this post from a (ahem) few years back:
https://forums.naimaudio.com/to...-do-you-replay-music
