Vinyl Storage Boxes
Posted by: Jack911 on 16 September 2015
Has anyone got suggestions for a storage solution for 12" vinyl?
I've seen some 100-LP travel boxes on Amazon but I'm not sure what the quality would be like.
It also needs to be big enough to hold multi-album releases which are contained in cardboard containers.
Posted on: 16 September 2015 by Fueller
I'm on the point of changing my vinyl storage and plan to use the 'Glorious' boxes which seem to be good value, fit for purpose and come in a range of sizes. Some of the usual rack manufacturers (Quadraspire  / hifi racks) have solutions but these are more expensive and seem less flexible.
Chris
Posted on: 16 September 2015 by Naijeru
I use some wire baskets like this for mine. They're $25 a pop at CB2.
Posted on: 16 September 2015 by CariocaJeff
As above the Glorious boxes caught my eye Also  the i-cubes which are available in many colours and wood effects, but a bit more expensive than you can get the larger glorious box for.
Posted on: 16 September 2015 by christoph
Chris
I use them, they are great, built as tanks!
Posted on: 16 September 2015 by Lunicycle
I have just been looking at the Glorious 230 boxes and can't tell whether they could be used vertically i.e. with the opening upwards. In all the pictures they are shown with the opening to the side, has anyone got one who can confirm if they are equally strong in all directions. Thanks
Posted on: 16 September 2015 by Steve J
For those in the UK these look pretty good, if it's boxes you're after.
http://www.reallyusefulproduct...rub/b19_0litreXL.php
Posted on: 16 September 2015 by Sneaky SNAIC
Local guy in Olympia I'm working with...
http://www.olympiarecordcrates.com/
Simple, strong, cheap.  Asking him if I can get Cherry.
They are similar to some I bought from Habitat in the '70s. I still have them in the garage.
Posted on: 16 September 2015 by hungryhalibut
I've got a few of the original 70s Habitat Palaset boxes that I'm about to take to the dump, if anyone wants them let me know. My forum name at gmail will do it.
Posted on: 18 September 2015 by Sneaky SNAIC
Ship to Seattle? What color?  My room has all dark furniture, etc.  Pictures?
