Naim Dac with Mac mini
Posted by: shahar on 22 September 2015
Hi
I want to upgrade my digital source.
Rest of the system: nap200+nac282 + B&W 804Dimond.
I have a Mac mini.
I don't care much about a streamer.
I want it to be Naim - so no Hugo or any other company.
I have as well a dedicate transport - Musical fidelity M series transport. I mostly listen to vinyl, and the Mac mini most of the time is for movies and very rare I listen to music through it on the backround or if I'm not in the mood to concentrate in the sound anyway.
Based om my presences above - My questions are:
1. Can a Mac mini be connected well to the Naim Dac with the USB or do i need to use this headphone optical connection? Is it good conection  considering I will use it for movies and background music?
2. Does the Naim Dac much better then V-1 Dac ?
3. Is it make any sense to go with the V-1 because the USB if anyway I listen most to cd's when it comes to digital?
3. What will be better when It come to cd playing - Ndac with some transport like mine, or cds2\3? And if I add a power supply to Ndac do you think the answer change?
4. Any other idea for the best sound solution by Naim  if I want great cd system and still Use my Mac mini for movies and little music here and there ... I will be glad to hear any crazy idea.
Thanks for your help!!!
And please - no Hugo, no Chord - I don't like the way they look - just Naim!
Shahar
Posted on: 22 September 2015 by James L
Given the Mac isn't for "critical" music listening, the optical will work fine.
It's not my preferred choice though. Rather I use USB > SPDIF converter (Halide Bridge) > nDAC.
The optical connection to me sounds a bit dark and laboured.
The MF transport should be pretty good in front of an an nDAC.
I used a MF A5 CDP for a while into an nDAC with excellent results. I then went to a CD5XS/nDAC.
If you do play music via the Mac, make sure you have decent playback software.
Amarra HiFi is very good value for money.
Posted on: 22 September 2015 by shahar
Thanks James,
so you bought the cd5xs just to be a transport? Is it worth it?
Yes, the CD5XS/DAC combo is awesome.
Posted on: 22 September 2015 by HamiltonNZ
I also use this combo and it's awesome.
Flettster
Posted on: 22 September 2015 by winkyincanada
The mini  is just fine via optical to the nDac. The later Minis (anything less than 4 years old?) have lower jitter and reportedly sound better if you want to use the optical connection directly.
I tried a Halide Bridge cable, but had two fail in a row. I gave up.
I predict that you will move more and more towards computer-based audio. The convenience and lack of clutter is a real appeal.
I use BitPerfect, mainly for the automatic bit-rate switching, but perhaps also sounds a bit better.
Posted on: 22 September 2015 by nbpf
Originally Posted by shahar:
Hi
I have a Mac mini.
Shahar
1. You should be able to connect a mac mini directly to a Naim DAC via optical SPDIF or indirectly, through a USB to SPDIF converter, via optical or electrical SPDIF.
2. I do not know, I have not made a direct comparison.
3. Possibly. The V1 also has a pretty good headphones out.
3. I do not know, I have no experience with Naim CD players. A power supply is reported to bring a significant improvement to the Naim DAC but I have not yet tested it.
4. No, I have no experience with Naim CD players.
Posted on: 22 September 2015 by Jude2012
Hi,
I have a similar set up to you and my thoughts are:
  1. Others have commented on this, essentially two options: a USB to SPDIF bridge or optical cable  (search under Guido Fawkes and you'll see a lot of info on optical). There is a maximum limit of 24/192 with SPDIF in the NDAC with PCM files (24/384 with the V1's asynchronous USB) - for CD rips this is not an issue.
  2. I auditioned both when buying the V1 I have now and preferred the V1 presentation at that time. I suggest that you try out both.
  3. The V1 is designed to primarily for use with a computer such as the Mini (it's SPDIF inouts are great, too. The NDAC just plays back from USB sticks).  The answer to which you prefer, to an extent, depends  what feel about question 2.
  4. No experience of Naim CD players. I'm sure you'll  get a a variety of responses here.  If you want to stick with Naim for a DAC, then a CD Naim CD player and the V1 or a second hand NDAC fits.  If not, then a Naim CD player and any DAC (Audioquest Dragonfly perhaps for example).
Jude
Posted on: 23 September 2015 by shahar
Thank you for the answers they really help. I should say I have a Dac (musical m1dac) and I just want a better one.
I will not move to computer based system. 90% of the time I listen to vinyl 9% for cd's and 1% computer.
It's just the Mac mini is there, and if I'll just buy a CD player it's mean I need to stay with my Dac for the movies and Mac, and My thinking is if I upgrade for Naim Dac I will upgrade the Mac mini and the cd's too and can get some money back for selling my Dac.
Posted on: 23 September 2015 by T38.45
ok, roon labs doesn't pay me but roon on mac is a killer :-) soundwise!
do this: macmini+roon sw+usb----dac or
macmini+roon sw+usb/spdif converter-----dac
control your mac headleass via ipad works, roon sw is available for test (think 20 days), if you don't like it just quit it.
Ralf
Posted on: 23 September 2015 by p.
As I wanted to have only one digital source, I sold my CD player and have all my CD-rips as well as the high-res-downloads and streaming-apps on my MacBook.
I have tried several ways to connect the MacBook to the nDac: different optical cables aswell as different usb-s/pdif-converters: I have not managed to find an optical cable that I liked sound-wise, they all sounded like a curtain covering the speakers.
Currently I use Audiophilleo2+PurePower as USB-S/PDIF-converter and I really love it
Amarra Hifi on my MacBoom brings a real improvement over iTunes replay.
Recently tried a Jitterbug between MacBook and AP2+PP and liked the result, yet I'm not yet convinced the improvement is big enough to buy it...
Posted on: 23 September 2015 by Patu
Originally Posted by Wat:
The best way I found with the Naim DAC is to use a high quality optical cable such as the SuperNova from Wireworld or to use a USB to S/PDIF convertor (I have Musical Fidelity & April Music ones and the sound quality is different with the April Music Stello U3 been vastly superior to the MF)
Wat
I used to own Stello U3 also. It was good and outclassed my previous USB to S/PDIF converter but didn't match the one I currently use, TeddyPardo U2S. It uses the same XMOS chip than U3 but has its own PSU compared to U3 using USB power. Also it should have superior clocks. This made a HUGE difference in sound quality. U3 sounded muffled and veiled in comparison. U2S added clarity and punch to the sound, bass hit deeper with better grip. I used to think Naim DAC would eliminate the differences between the converters but it doesn't. I've also owned M2Tech HiFace and many other converters before. I guess my point is that It clearly isn't the same which way you connect your computer to the DAC.
Posted on: 23 September 2015 by nbpf
Originally Posted by Patu:
... I guess my point is that It clearly isn't the same which way you connect your computer to the DAC.
This is also my experience and in this respect I found the Naim DAC a bit disappointing. On the other hand, I have bought it second hand and for about the same price as a new V1 and I can understand that, given the way most DAC work (included NDAC and V1), they cannot be really source agnostic. I feed my NDAC via a M2Tech HiFace Evo powered by a 9V Teddy Pardo power supply. Best, nbpf
Posted on: 23 September 2015 by AllanDB
Unfortunately, any mention of dac or source, inevitably, directly or indirectly, hugo will appear ......
Thanks again for the help.
computer music is not the main thing for me and I think I got the idea.
Did Anyone have been tried the naim Dac or v-1 feeded by dedicated cd transport in compare to a cds2/3 or cdx2? Which one is better and if so how much better?
Posted on: 23 September 2015 by Jude2012
https://forums.naimaudio.com/to...64#49295593307589864
Posted on: 24 September 2015 by Disposable hero
Naim DAC is better than DAC V1 and for connecting any Mac to the DAC, it is fine with a WireWorld Supernova 6 which will be 3.5 optical SPDIF straight to the Naim DAC.  No need to fanny around with USB to SPDIF conversion things, unless you really can hear massive improvements by taking those options.
If Vinyl is really your main playback, then you could also consider Chord 2Qute DAC which some people will say has more 'vinyl-like' characteristics.  it is not a Naim product however if you look at the price level of the Chord 2Qute and its physical dimensions and hear a good quality sound, it is likely to be a decent value option.
Posted on: 24 September 2015 by charnik
-Does it makes any difference to where music is stored? examples: Mac mini's internal HDD, external USB HDD, or NAS
-Any advantage replacing mac mini's power supply?
-USB to SPDIF solutions are better than a UQ2 ? In some cases the cost is comparable to UQ.
-Anyone have tried upmarket USB to SPDIF converter like Weiss INT204 with Ndac?
Posted on: 25 September 2015 by Briz Vegas
in short, yes.  I get better results with the current setup than without the upgrades. Namely SSD Macbook with max memory, music on USB hard drive, Ndac / XPS2DR linked via firewire Weiss INT202 and Nordost digital cables.  Add A Paul Hynes SR7 dual rail to run he Weiss and the Macbook and it becomes a very expensive source.
Starting again i would look at a Chord 2qute first.
Posted on: 25 September 2015 by Jude2012
Great to hear that the Audiiophilleo gets good results with the NDAC.
It is this tech that is used and amazingly intergrated into the V1.  I have tried some modest optimisations of the Mac Mini and seen no significant change in SQ, which I conclude is down to Naim and Audiophilleo's design in keeping out noise from the Mac Mini (or other computers) on Asynchronous USB  and sources/transports using SPDIF.
Posted on: 26 September 2015 by Jude2012
I largely agree with Wat's points regarding Audirvana and MM (albeit that I do not use room correction or forced upsampling features in Audirvana or a SSD ( yet) ).
My conclusion regarding USB to SPDIF bridges is that in DACs with minimal noise rejection from sources/transports built in (such as the NDAC and Hugo), there is a stronger need for these.  In DACs like the V1 and 2Qute, with noise rejection designed in , the need is very low / un necessary.
Posted on: 26 September 2015 by Patu
USB to SPDIF solutions are better than a UQ2 ? In some cases the cost is comparable to UQ. Anyone have tried upmarket USB to SPDIF converter like Weiss INT204 with Ndac?
April Music Stello U3 (XMOS design like Chord uses) is very good; also converts to balanced AES/EBU, irrelevant for Naim DAC, but useful for other DACs. To power it, I use iFI iUSB. Worth looking at iFI audio's site if you're tweaking, but you can become gadget strewn. Unsure why you'd use UQ between MM/DAC, if using UQ as digital transport try VortexBox instead of MM.
Wat
As I wrote earlier, I used to own Stello U3. It's very good performer but suffers from the use of USB power. I never tried it with 3rd party solutions like iFI USB but I'm sure powering it better will improve the sound. I still strongly recommend trying out TeddyPard U2S since there you you have the great XMOS chip and great PSU in same package.
I remember when the first USB to S/PDIF converters started to appear on the market. M2Tech HiFace was probably the first one and I had to get it immediately. Even then the improvement over optical/coaxial connection from soundcard was clear. I used professional sound cards by ESI or M-Audio back then, not the integrated ones on the motherboard. Even they didn't match the HiFace. Now I haven't heard MacBook optical out but I feel little suspicious that it could match the external converters. Professional sound cards on PC couldn't match.
Posted on: 26 September 2015 by shahar
Wow you are really helping. Thanks!
Since I don't won't to go with USB converter in the middle I think I'll upgrade to the V-1. Most of what I read here and elsewhere considering the optical cable option as a poor one in compare to the USB.
For sure if the Ndac had the USB I would have put the extra money on it. The other thing is that it really old gear, and I don't want to buy it just to realize few month later or a year later that Naim are making a new one (it's happened to me with the 200DR..). And If they will, I have a second system in the room and an office office which can enjoy the V-1 when I upgrade.
My thought process was very similar two years ago and I haven't regretted it all.
Jude
Posted on: 01 October 2015 by shahar
So life it is want yapping to you when you buddy in make your plans?
I don't know how, I talked to an old a friend, which have a perfect CDi, and he suggested to give it to me in exchange to some dynvector cartridge I don't use. A night meeting, nice conversation, some checkings, and today I have a really new CDi playing at the main system.
The Dac I have will stay because any way like I said I use it 1% of the time and my thinking was for a better cd's playing.
And the CDi is rocking! I can't believe how good it is in compare to any other digital music I used to. Now I just hope it will live long!
Sorry on the typos from my iPhone...
