n-Stream and iOS 9
Posted by: Kevin Richardson on 23 September 2015
Just checking to see if the "old" n-Stream app is compatible with iOS 9.  I greatly prefer n-Stream over Naim app.
Posted on: 23 September 2015 by Ian F
Hi Kev,
I updated the iPad last night and nStream seems to be working just as it did before.
Hope this helps!
Ian
Posted on: 23 September 2015 by Clive B
And I thought I was the only one still using n-Stream...
Posted on: 23 September 2015 by Igor Švab
"Naim" app is replacement for "n-stream" app.
I prefer the looks of the n-stream app. How do you make it work on IOS9?
Posted on: 23 September 2015 by Kevin Richardson
Originally Posted by Ian F:
Hi Kev,
Hope this helps!
Ian
Thanks for the info.
My greatest hi-fi related fear is that one day n-Stream will stop working with a version of iOS.  I plan to never make the switch to the Naim app.
Posted on: 24 September 2015 by David Hendon
The n-stream App is a bit clunky if you have more than one streamer and the naim App is very good in that regard.  I liked the look of the old n-stream App but I wouldn't go back now that I'm used to it, even if I could.
best
Posted on: 24 September 2015 by nickpeacock
Since one of the Naim app updates incorporated the optional function to call up a menu when you click on a track, instead of playing it straight off, which gives it more or less the same functionality as the old n-stream app, I am happy with the new version. I had an appalling time with the Naim app and my old Sony xperia phone - had to revert to n-stream and an iPod touch. But am now back to my usual zen-like self...(!)
Posted on: 24 September 2015 by Kevin Richardson
Well that is good to know.  Ill give it a try on my wife's iPad.
Posted on: 26 September 2015 by nickpeacock
@Kevin - did you get it working ok? (There's an option in one of the menus you have to select.)
