How I create playlists for the Uniqute
Posted by: Scarydog on 24 April 2011
Hi all,
Well after a lot of to and fro I have finally got a workable system for creating playlists.
My Setup:
nstream app on iphone
nasgear ready nas duo
So I have all my CD's ripped to the duo and shared via uPnP. That all works fine but as you know n-stream can't create playlists. I find this problematic - I like to cue up 3 - 5 albums for a morning of listening. This was easy on the Squeezebox duo - start the first album and then push the add button every time I found a album I wanted to listen to.
So this is what I've done. I have squeeze center running on the ReadyNas duo and make my playlists there. I have added playlists to the readydlna sharing and have it sharing the folder where Squeeze center is placing the playlists. Because ReadyDLNA (really MiniDLNA) and Squeeze center are indexing the same folder of flacs all of the paths are correct.
So this works reasonably well.
I hope this helps someone :-)
