New User Feedback
Posted by: JLF on 02 May 2011
Not sure if this will be of any use or interest to anyone here but I just wanted to say a bit about my entry into the world of Naim audio as a new user.
Last week I invested in a Uniti and Serve set up (upgrading from Arcam) and using my existing Monitor Audio spkrs and I have just spent the past weekend puting it all together.
My first impression is that this kit is absolutely flipping fantastic! I love it! The installation went pretty smoothly - Uniti and Serve talking to each other nicely via Netgear WiFi network and controlled from my armchair with the n-stream App on my iPhone.
I had just two problems during installation -
- The DTC couldn't find the Serve which I finally discovered was my over zealous McAfee AV software stopping it connecting to my network. Easily solved by adjusting AV settings.
- The Serve has rejected about 12 CDs during the ripping stage ( I've successfully ripped about 40 so far ). Well, it doesn't really reject these discs rather it can't seem to detect them in the first place and just sits there making a rather nasty groaning sound. However, I can abort the ripping process and continue ripping other discs with no problem. I have also copied the discs that the Serve doesn't like to new blank discs ( Memorex ) and these have then ripped without problem. Looks like a problem with the physical construction of some discs - size? weight? smell? - who knows?
Hopefully this issue with the Serve won't develop into a bigger problem later.
Anyway, thanks Naim, wonderful kit, great sound, and I am rediscovering music not listened to in ages. Brilliant!
JLF
