Uniti serve and NAS
Posted by: JLD on 29 September 2015
Hello
Is it possible to change the destination directory for ripped files from an uniti serve with Nserve application ?
Tanks in d'avance
Jean-Luc
Posted on: 29 September 2015 by David Hendon
If you mean through the n-serve application run on an IOS device then I think it isn't.  But you should be able to do it using the Windows desktop controller.  If you mean n-serve running on a MAC, then someone else needs to advise you as I don't know about that.
best
Posted on: 29 September 2015 by Jan-Erik Nordoen
As David says, it is not possible through the nServe application (on iOS or Android), but you have four other possibilities to do this :
1. Via the Windows desktop controller
2. Via n-Serve running on a Mac (under the Maintenance menu)
3. Via an external monitor + mouse (or keyboard) plugged into the UnitiServe (or a touch screen)
4. Via a web browser : http://nssrvXXXX, where XXXX is the number printed on the back of your Serve.
Options 3 and 4 provide essentially the same interface.
All will allow you to nominate a music share (on a NAS) as a Music Store (where the ripped CDs are stored).
Jan
Posted on: 29 September 2015 by JLD
David, Jan-Erik
Thank you for your responses.
The uniti serve is at a friend.
In the past I've used the windows controller...
The solution 4 is probably the simplest way for me.
Thank you very much
Jean-Luc
You're welcome. I accept St-Nectaire, Cantal or fourme d'Ambert.
(la France me manque... je m'ennuie des années passées à Lyon)
Jan
Posted on: 29 September 2015 by ChrisSU
Jan
Just to be totally pedantic, a 5th option is to type the Unitiserve's IP address into a browser.....
Cool. I'd forgotten about that.
Jan
Only a true Frenchman would accept payment in cheese!!!
Not just the French. Some Italian banks accept Parmesan* as collateral for loans.
http://www.cnn.com/2013/08/15/...san-cheese-bank-mpe/
(* Reggiano)
Posted on: 30 September 2015 by JLD
Hi Jan!
That could be possible
here is my dealer
http://www.cantal-destination....AUV015V504XAU-1.html
(Chris, thanks for 5th way, that's logical)
