Sink Hole Observation
Posted by: SongStream on 01 October 2015
Scary things sink holes, but could I draw your attention to the barrier situation.  This appears to be directing drivers to fall into the left side of the hole, which makes sense. However, the obvious mistake is that the is no equivalent guidance on the other side.  Doh!!!
Posted on: 01 October 2015 by james n
I suspect it wasn't that big when they first put the barrier there...
